700efi intake
Old Aug 22, 2007 | 12:29 PM
kwiknik2's Avatar
Default 700efi intake
Has anyone else have their plastic intake( between the carb and head) crack or break?[img]i/expressions/face-icon-small-shocked.gif[/img] I find this to be an odd mechanical failure.
Old Aug 22, 2007 | 05:36 PM
jdaddy's Avatar
nik, is this under your airbox, seat, and tank? how did you discover this problem? sound odd. well i guess you could fix the problem and put the 800 air box in.
Old Aug 22, 2007 | 06:19 PM
kwiknik2's Avatar
When I would rev it it would pop. So I kept looking until I saw fire coming from under the tank when it popped.
Old Aug 22, 2007 | 07:26 PM
SCRAMMYTODD's Avatar
I've heard of this but not on Polaris quads. One Arctic Cat and lots of times on sleds.
Old Aug 22, 2007 | 10:39 PM
Diesel3247's Avatar
yep, just had it happen a couple of weeks ago. got the new part and put it on. the best way to do it is to take the front plastic off, the fuel tank out, and then you can have access to your throttle body. you might as well clean that while you are at it, and make sure you clean the sealing point on the jug. i also cleaned my air cleaner box, and air tube from air box to the throttle body but take off the sensor (t-bap). it pretty easy that way. take it a part from airbox to the jug to make life easy. yeah, this was/is a common problem because they upgraded the part and made an better one. not worth a recall item but worth an upgrade.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Sassinm1
Sep 30, 2015 04:23 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
