Guru's HelpASAP!!!!!
Old Aug 29, 2007 | 04:04 PM
DragonDJ11's Avatar
Default Guru's HelpASAP!!!!!
What all possible causes of a stock piston hitting the intake valves??? How much damage could have been done? Still safe to run that head with those valves??? Help!!!!!!
Old Aug 29, 2007 | 04:10 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
usually it is from floating your valves do to over reving the motor and your valve springs are to week or a timing problem. As far as running the valves I would go have them checked for being true or you could cause seriouse damage to your head if their is not already damage.
Old Aug 29, 2007 | 04:18 PM
Scatterbrain's Avatar
Which bike brent? Big D's?
Old Aug 29, 2007 | 04:25 PM
DragonDJ11's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Scatterbrain
Which bike brent? Big D's?</end quote></div>
Yep on his. We thought it was an exhaust leak with those LTE's, but now it appears that it was not. I had a ported head with shim unders and 109 cams on it. The top of the piston is scrapped where the intakes are. I must have screwed the timing when I messed with it last. The line on the exhaust cam sprocket was exact, but the one on the intake side was up about 2 teeth I am guessing. I don't understand why it would have been off. I was very cautious of that when I installed last time
Old Aug 29, 2007 | 04:30 PM
DragonDJ11's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Tpsycho
usually it is from floating your valves do to over reving the motor and your valve springs are to week or a timing problem. As far as running the valves I would go have them checked for being true or you could cause seriouse damage to your head if their is not already damage.</end quote></div>
I was hoping timing would not be an answer, as that makes it my screw up!! Fill in a line of un-usable adjectives currently being thrown at myself!!!
Old Aug 29, 2007 | 05:38 PM
DragonDJ11's Avatar
Ok here is where we stand. Thanks to Eric, and a quick simple test we were able to determine that one valve is bent. So yes, that is a bummer. However, I did manage to find a builder close by that can swap the valves for me. I have some extra in another head that I just happen to have sitting around. This is why I horde every part I can get my hands on. So it is now looking like what was close to a huge bum out, is now just a little hurdle. I should still be all back together and on the road early Friday morning. Thanks for the imput....
Old Aug 29, 2007 | 06:13 PM
650VIPER's Avatar
Brenton, if the builder cannot get them done, let me know. I can bring the valve press and we can do it there.
Old Aug 29, 2007 | 06:28 PM
Tpsycho's Avatar
I would check the specs on your came chain tentioner and make sure it is all rite just in case I doubt it is the culprit but their is always a possability.
RticKwad
12
Jul 19, 2015 12:22 AM
Stealth Hunter
Feb 4, 2009 09:47 PM
700 sportsman
Dec 19, 2008 04:46 AM
GuitarPicker
Feb 11, 2008 10:34 PM
