Tires
Old Aug 29, 2007 | 07:04 PM
trunner's Avatar
Default Tires
my 350 has 24 x 9 - 11 size tires. is it possible to put 24 x 9 - 12 or 10 - 11 tires on the same rim?
i wanna buy from ebay and there is not a big selection of 9 - 11's but lots of others. any help would be great.
Thanks
Tom
Old Aug 30, 2007 | 03:25 AM
kizmo's Avatar
Default Tires
hi their.. first of all the 11 is your rim size.. (so your 24x9-12.) the 12 in this case is your rim size. but if the bolt pattern are the same i dont see y not. Ive got an 87 350 trx 4x4 an ive found me a set of 25x10x12 for the back and 25x8x12 for the front that came with rims an all, off a 95 or 96 yamaha kodiak, the bolt patterns were the same. got lucky their , So maybe you can start their. just remember that you can go big but as long as your bolt pattern are the same.. well i hope you find what your looking for........
Old Aug 30, 2007 | 03:26 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default Tires
The first number is the tire diameter. The second number is the tire width. And, the most important here, the third number is rim diameter.
You have lots of leway on different tire diameters and widths, but you have absolutely no leway on the rim diameter....it must be an 11".
Old Sep 2, 2007 | 02:47 AM
olyguy12's Avatar
Default Tires
Typical Honda issue. Get a set of aftermarket 12 inch diameter rims to fit the bolt pattern and get the size of tires KIZMO mentioned. The 25x10-12 and 25x8-12 are the most common size tires in the industry. If you go after a set of used wheels make sure they fit swing arm axles and not independant suspension axles as the offset is different.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
