Sport Quads Discussions on sport quads.
more power
Old Aug 31, 2007 | 11:40 PM
03z400yoshi's Avatar
Default more power
i own an 03 z400 with a full yosh pipe, jet kit, k&n and open air box. im looking to get a little more power all around (top-bottom end). i wanted to put the 440 kit on but i was told it will decrease the reliability of my bike alot. how about a cdi and a edlebrock carb, i know they will both give me more power but im also not looking to loose that much reliability in my bike and im not sureif its worth the $600-$900 and will i get that much more all around power out, what are some other suggestions.
Old Sep 2, 2007 | 12:27 AM
Doctorturbo's Avatar
GOT BOOST!
Default more power
You already have the bolt ons. Your next move is to get into the engine. Carb and cam would be the next move for me. Then maybe a slightly higher compression piston.
Old Sep 2, 2007 | 01:02 AM
Default more power
ok if i go with hot cams, a cdi and a bigger carb will that add a sebstansial amount of power and will it decrease the reliability alot?
Old Sep 2, 2007 | 02:03 AM
GOT BOOST!
Default more power
I don't have a Z so this will be from my engine building experiance and tuning.
Substantial is a very subjective word. An well ground cam matched with the other parts you have will wake up your engine. So yes, you will be able to feel quite a bit of power.
Will it decrease reliability? Well, sure but not to the extent that it will become unreliabile. If you or the shop that does the rebuild does a good job, you should not have to worry about that.
I'm sure that someone else on this board will come along and answer your question better than me. There must be a lot of people on here that has done this mod on a Z.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
salixair
Nov 3, 2015 08:25 AM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
