HELP ME GUYS!!!!!!!!!!!!!
Old Jan 3, 2001 | 11:10 AM
NCMOJAVE250's Avatar
WUS UP FELLAS I JUST got a 88 warrior and its been sitting for 7 months i got it home and the float was stuck so i took carb apart and soaked it in gas over night and im gonna clean jets and do u have any tips or tricks i should do before putting it back together????
thanx
Old Jan 3, 2001 | 12:10 PM
dsEATER's Avatar
Pull a peice of a wire brush's wire bristle out and use it to run through the pilot and main (make sure it's smaller than the hole and not reaming them out) This will remove any unwanted tarnish, then use a blow gun to blow them out and the holes they screw into. Use some scotchbrite to clean the needle and seat.
Old Jan 3, 2001 | 04:21 PM
deeznuts's Avatar
make sure the accellerator plunger is working properly. It is the plunger on the side of the carb if you remove the cover where the throttle cable goes in, and has a rubber boot around it. they hang up alot.
bafisher1986
Jul 21, 2015 04:12 PM
rcappie4
Jul 18, 2015 07:51 AM
Robinhood
Jul 13, 2015 09:13 PM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
