Trouble with Sundiro 90 - HELP!!!!
Old Sep 2, 2007 | 07:21 PM
PortlandBanshee01's Avatar
Default Trouble with Sundiro 90 - HELP!!!!
Just picked up two Sundiro's a 90 and a 50. Now I am trying to get them to run! Any suggestions gladly accepted... The 90 cranks and everything but I have no spark. Any clue what might be the cause and where can I find parts for them?
Thanks for your help...
Old Sep 2, 2007 | 11:05 PM
SilveradoSS's Avatar
Check the kill switch position on the handlebar. Make sure it's in the run position. If that is OK, check the safety tether cord on the back of the quad.
Old Sep 3, 2007 | 12:13 AM
The kill being the on off?I cleand all of the grounds and pulled the plug and now it looks like I have spark... But cant get it to fire up... Puled the carb apart and cleaned it..So I'm not sure why it wont start?????
Old Sep 3, 2007 | 07:58 AM
<div class="FTQUOTE"><begin quote>Originally posted by: PortlandBanshee01
You have a keyed switch and then there is another switch on either the left or right handlebar that will shut off the engine by cutting the spark to the cylinder.
Old Sep 3, 2007 | 08:00 AM
If you have spark, then I would try shooting some starting fluid into the spark plug hole and try to start it again.
Old Sep 3, 2007 | 11:17 AM
billl2099's Avatar
you didn't mention if you purchase these new or use, if they were used or new, you need to replace the spark plugs on both, NGK c7hsa, i take it the 50 runs, so all the electrical on the 50 will should fit the 90, cdi, handle bar switche, so force, you can start swiching parts until you find the problem, but the very first thing i would do if you have a spark would be to replace the spark plug and if that didn't work then you need to adjust the valves.
Old Sep 3, 2007 | 11:27 AM
400CatDriver's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: billl2099
just say no to chinese junk</end quote></div>
Amen, brother. I wish people would stop buying the Chinese crap and buy something from reputable dealers. It won't be a problem much longer...no one here will have jobs anyhow.
No offense Portland.
Old Sep 3, 2007 | 02:58 PM
They are both used and I didn't by them... I myself own 2 banshee and working on a third but a guy I know found them the Sundiro and wanted one of them for his kid... He said if I can get the 90 running the he will give me the 50 and for free this is something my granddaughter would love for her first quad..
I'm going to try and get the 50 running today and go from there.. And do a compression test on the 90... these are 2 strokes so they don't have values
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
caveeagle
Sep 19, 2015 01:20 PM
