Polaris Diesel
Old Sep 4, 2007 | 02:15 PM
Klinger's Avatar
Default Polaris Diesel
I'm having what appears to me as a electrical problem. I was on a trail when with no warnings it died. It was if I shut off the ignition. After checking the battery connections, it started up agian. I headed back and it died 5 more times on the way back. Luckly I had only 2 miles to go. Each time it died, I wiggled the battery wires (the lugs where tight but corrosion was formed) and the wires around the ignition switch. Everything seemed to be good (besides the corrosion) and it would start up agian. On 2 out of the 5 times it died, it bogged down and it felt like I had only 10% power. After 30 seconds of this it would die, but start up eventually. I'm going to buy a new battery, clean the terminals, and check for loose igition wires, but I'm not 100% sure this will solve my problem. Any suggestions of problems and solutions in the past would be appreciated because the Polaris Diesel is definalty one of a kind.
Old Sep 4, 2007 | 04:43 PM
HeftyLefty's Avatar
Besides wiring check your filters and fuel pump. You can download a manual at the Polaris site. Check all electrical connections for corrosion.
Old Sep 4, 2007 | 06:50 PM
eli98's Avatar
definately sounds fuel related
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
