diagnostic mode
Old Sep 5, 2007 | 07:21 PM
embler's Avatar
Default diagnostic mode
on my '03 sp 700 when I go into diagnostic mode it only displays 3 different screens. it this right? screens are, voltage, what looks like oil pressure and tach. I've read where others have more than 3 on theirs. also, on the second screen it looks like it says oil pressure. when I start it up in the diagnostic mode, the voltage display goes up as normal and the tach screen works but the oil pressure one does nothing. is it suppose to? am I missing something? I figured it would at least display oil pressure.
Old Sep 5, 2007 | 10:57 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
there is no oil pressure gauge that im aware of. what does it look like or say in that screen?
Old Sep 6, 2007 | 01:26 AM
dosceola's Avatar
when u start quad diagnastic mode should go away. theres no oil pressure reading. if u have 4x4 it should give u switch yes or no , an hour glass for maintence intervials, MPH or KM choice.
Old Sep 6, 2007 | 05:48 AM
Mud Hog's Avatar
Kind of an aside but I would sure like an oil pressure guage on an atv with the shenanigans I went thru last week with oil.
Old Sep 6, 2007 | 12:48 PM
embler's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: dosceola
when u start quad diagnastic mode should go away. theres no oil pressure reading. if u have 4x4 it should give u switch yes or no , an hour glass for maintence intervials, MPH or KM choice.</end quote></div>
mine doesn't have that. mine is a 4x4 but it doesn't have a yes or no or a mph/km choice(not a digital speedo). i checked it out and the wrench and oil icon comes up and it says pr55er which i would assume the 5's are s's.
Old Sep 6, 2007 | 01:20 PM
duffus's Avatar
i've seen some pics where ppl intall oil pressure gauges-- but never looked myself where to hook up on the engine. thoughts?
Old Sep 6, 2007 | 10:32 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
so you dont have the newer(04' and up i think)style speedo w/ the same features as ours. dont know what there would on them.
Old Sep 12, 2007 | 11:10 PM
Schneider600's Avatar
I am having the same issue, I just bought a used 2003 600 twin in nice shape, I tried the diagnostic and I am gettng the same "pr55er" I would love to knwo what it means, lemme know if you find out, hope its not bad [img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 12, 2007 | 11:15 PM
Found it in another thread, Embler, check it out.........
It's in my owner's manual, 2003 600/700 Sportsman. "Diagnostic Mode" It's to check oil pressure, set idle (tach mode), and check voltage.
Here's what the book says:
"The diagnostic mode is for informational purposes only. Please return your ATV to your dealer for all major repairs.
To enter the diagnostics mode:
1. Turn the key switch off and wait 20 seconds.
2. Set the park brake and shift the transmission the neutral.
3. Hold the mode/reverse override button and turn the key switch on.
The initial screen displayed looks sinilar to the top illustration and refers to the software version installed in your ATV. This information is displayed breifly.
Use the mode/reverse override button to toggle through the diagnostics screens. The first screen displays battery voltage.
<span class="FTHighlightFont">The second screen provides full diagnostics for the entire oil pressure electrical circuit. Along with the letters PrSSr, there will be a box on the left side. If the box is high, the pressure is normal. If the box is low, the pressure is low.</span ft>
Screen three is the tachometer for setting idle speed. If this needs adjustment, please contact your dealer.
As long as the center is in the diagnostic mode, the wrench icon will reain lit.
To leave the diagnostic mode, either shift the machine out of neutral or turn the key switch off and on. NOTE: Any movement of the tires will also take the machine out of the diagnostic mode."
Old Sep 12, 2007 | 11:16 PM
embler's Avatar
I'm gonna call my local polaris place and ask about it tommorrow.
