new piston rings help
Old Sep 6, 2007 | 07:23 PM
a_diehard_pats_fan2000's Avatar
Default new piston rings help
Im putting a new piston in my honda foreman 400 and dont know where the top rings go..i mean what ones go where..one has a tapper on it the other doesnt..and one looks a little wider than the other
Old Sep 6, 2007 | 10:10 PM
HondaMechanic's Avatar
The chrome ring is the top ring .. The black ring is the second compression ring .. And the "T" goes up ...
Old Sep 6, 2007 | 10:54 PM
well there both kinda black..but one has a slight bevel on it.is that the top one
Old Sep 6, 2007 | 11:09 PM
Old Sep 7, 2007 | 10:05 PM
OK im pissed..I just put new piston and rings in and the thing still smokes bad..no blow by in the case vent thought..does it take a brake in time for the rings
Old Sep 8, 2007 | 07:44 AM
HondaTechnician's Avatar
I have to assume that you had the cylinder properly honed before installing the new rings.
I would also assume that you properly spaced the ring end gaps upon install.
I also assume you oiled the piston and cylinder for assembly.
If this is not a job you have done before, it is very easy to break a new ring installing the piston into the cylinder.
There should be little to no break in time required. After assemble it should not smoke, HOWEVER, if the exhaust was full of oil from the previous engine damage it can over an hour of normal riding to burn that out. So, if your confidant that you done a good job on your rebuild, ride it for a while, and see if it quits smoking, if so, it was just oil in the exhaust. Like I said, that is normal on one that has had a badly blown engine before.
Joe454
Nov 20, 2020 01:19 PM
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
