Top dead center and the T mark on flywheel not lining up
Old Sep 7, 2007 | 03:30 PM
Brobones's Avatar
Default Top dead center and the T mark on flywheel not lining up
Here is my dilemma;
Recently purchased a 1984 200ES big red.
Just to make sure that it is a 200ES here is what it has on it
Electric start, with hand recoil. High Low and Reverse. Shaft driven
My troubles, the chain guard tensioner and guides were worn out on this bike. I replaced those and a new chain along with cam sprocket.
The problem that I have having is that when I have the flywheel set on T the piston is actually not at its highest point. If I rotate the flywheel further (Counter Clock wise) then the piston comes to top dead center.) I am talking about rotating the flywheel another 30 or so degrees.
Has anyone else come across something like this and if so how could of this happened.??
Any info in regards to my dilemma would be greatly appreciated. TIA
Bro
Old Sep 8, 2007 | 04:54 PM
HMFIC's Avatar
Make sure that the keyway is good on the crankshaft where the flywheel goes on. That is the only thing i have seen cause this. I have had more than a few shear the key way off. It is generally from someone who worked on it and didnt tighten the flywheel properly.
chingchangchong
Aug 7, 2022 11:36 AM
black_thunder
Sep 20, 2015 10:21 PM
Canamaniac!
Sep 15, 2015 06:19 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
WilliamBos
Sep 6, 2015 10:53 AM
