HUB ???
Old Jan 3, 2001 | 07:56 PM
MUDDYONE's Avatar
WHAT KEEPS THE SEAL SLEEVE THAT THE COIL IS MOUNTED TO FROM TURNING??MY COIL WIRES WERE CUT WHEN THE CHANNEL ON THE SLEEVE TURNED ABOUT AN 1/2 INCH.
Old Jan 3, 2001 | 08:18 PM
farmeral's Avatar
I dont know what holds it from turning but I had the same trouble on mine. I turned it counter clockwise marked it up a little with a small center punch, put on a bunch of red stud & bearing locktite and turned it back where it belongs (had to use a hammer & punch). I hope this fixes it, it seems to be tight, I couldnt move it with hands. The coil that it cut had enough wire sticking out of it I just soldered it back togethor. 4x4 works again, I hope this lasts, I just did it today.
Old Jan 3, 2001 | 09:31 PM
Dazed's Avatar
We use silicone when there made. Same stuff u see on the inside of your strut housing the blue stuff.
Old Jan 3, 2001 | 10:52 PM
MUDDYONE's Avatar
THANKS FOR THE HELP.I WILL BE PUTTING IT BACK TOGETHER IN THE MORNING.
Old Jan 3, 2001 | 11:06 PM
farmeral's Avatar
Muddyone; I ment the steel sleeve that is pressed through the strut housing (where the axle goes through), not the cover(?)sleeve that goes over the coil. Mine would not move in or out, just rotate a very small amount, silicone holds the cover seal just fine.
