how much would 4 uni air box vents help on my 03 trx250ex
Old Sep 9, 2007 | 08:52 PM
Dillpick351's Avatar
Default how much would 4 uni air box vents help on my 03 trx250ex
i ordered some uni air box vents and wanted to know how much of a difference would it make on a trx 250ex
Old Sep 10, 2007 | 01:56 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Take a look at the end of your snorkle. The opening is about the size of a quarter....very restricted! The vents will help, but the little 250 can only handle so much air, so 4 or 5 is about all you can run. Run more, and it just won't jet right. Also, put them around the edge of the lid, because if they are in the middle they will hit the air filter.
While we are taking air filters, lose the K&N. Get a UNI foam filter, and save your engine!
Old Sep 10, 2007 | 04:52 PM
Dan250race's Avatar
keep them high so water will be less prone to getting in. I accualy preffer a outer wear on the filter and no lid and the drain tube open...makes for more dirt and maintenance, but it is too critical of a part to go un maintinaced as you know.
Old Sep 10, 2007 | 05:02 PM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
There not going to nothing but make it run lean without bumping up your jetting. A 110 or 112 main will do the trick. Bump up the pilot one or two sizes also.
ReconBayou
Oct 31, 2022 05:37 PM
SDR-II
Sep 29, 2015 01:06 AM
bvolks
Sep 13, 2015 12:57 PM
KSJOHN
Aug 30, 2015 08:15 AM
Captjay
Jul 23, 2015 12:33 PM
