polaris ??
Old Sep 9, 2007 | 10:06 PM
JT600's Avatar
Default polaris ??
My 600 twin was fine for 589miles. Tonight after a 7-8 mile ride I parked at my hunting spot to scout and after sitting for 45 minutes the thing felt like it has a flat, but didn't. It is pulling near vioently to the left or right like one wheel is locked in and out of awd. Any suggestions? It is a 2005 and hes very easy miles on it.
JT
Old Sep 9, 2007 | 10:34 PM
jodaanja's Avatar
Default polaris ??
You are describing the sympoms of too much "toe out" on the front wheels. Check your tierods....if you bent one, you will have too much toe out.
Old Sep 9, 2007 | 10:50 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default polaris ??
flat tire, toe in/out, bad bearings/cv joint starting to lock up. shouldnt be one wheel from the awd since that was the older style hubs. jack it up to free spin the front wheels one at a time to test for drag.
Old Sep 10, 2007 | 03:35 AM
Mud Hog's Avatar
Default polaris ??
I know you said that you didn't have a flat, but my 800 pulls quite a bit if the rear wheels are not close in air pressure. I would check the air pressure in all of my tires first and then check everything else. I had a small leak in my right rear tire and I could tell when it was going down cuz the bike would pull progressively worse. When looking at the tire, 27" mudlite xtr on 14" itp ss 108, it was hard to tell it was low. I think it's because the 14" wheels have a smaller side wall that doesn't bulge out as much when pressure is low. Good luck.
Old Sep 10, 2007 | 07:59 PM
JT600's Avatar
Default polaris ??
Thanks stendori,
I can't work on it till Thursday I'll let you know. I apreciate the suggestions.
JT600's Avatar
Default polaris ??
Thanks,
I'll be checking on Thursday
Old Sep 14, 2007 | 09:48 PM
JT600's Avatar
Default polaris ??
I jacked it up and both wheels rolled free. I let it down and it has been working fine since. II am baffled is there an impending problem that I can avoid? with some PM or something?
Old Sep 14, 2007 | 10:19 PM
kcebcj's Avatar
Default polaris ??
I have had a similar problem over the years with a 96 Sportsman 500. After awhile I noticed it seem to do it after backing for a distance. By the time I would get it back to my shop it would fix itself. To this day I don't know what causes it. If it happens with the new 07 I will definitely get it figured out.
Old Sep 14, 2007 | 10:23 PM
frankenfab's Avatar
Default polaris ??
My Sportsman 500 does that sometimes, and it seems to me like the 4 wheel drive is sticking on one side. I engage and disengage the 4 wheel and it goes away. I know what you mean, it is a VIOLENT pull to one side when trying to take off.
Old Sep 14, 2007 | 10:44 PM
Wenty's Avatar
Default polaris ??
Sounds like the 4wd is stuck. Had it happen on a few rides, different machines from others sportsmans, magnum and my explorer, it's always been taken care of by going in reverse. If it still sticks put it back in 4wd, back to 2wd, reverse. In my experiences it's been a pretty common occurance. I should add...mine did it quite a few times last fall, changed the fluid in the hubs, hasn't happened since.
