07 SPORTSMAN 800 REVERSE LIGHTS
Old Sep 12, 2007 | 07:24 PM
97SOLOMA's Avatar
Default 07 SPORTSMAN 800 REVERSE LIGHTS
I have done a search and i come back confused, is there a way to hook up reverse lights on my quad, it looks like its possible in the brake lights??
thanks in advance!
Old Sep 12, 2007 | 07:43 PM
SCRAMMYTODD's Avatar
Ya it's possible. The wiring is there at the lights and the wires are in the pod as well. All you need is a switch and some bulbs as far as I know. Make sure you get a good quality waterproof switch.
Old Sep 12, 2007 | 08:23 PM
davidaz's Avatar
My 07 800 has a bright backup light with a toggle switch near the key. Polaris should have those as replacement parts.
Old Sep 12, 2007 | 08:51 PM
Mine came with them as well. Apperantly the Polaris switches are expensive, if you do a search Stendori found aftermarket ones with a light in them for cheaper and they look factory
Old Sep 12, 2007 | 08:54 PM
trailbound's Avatar
I think quadovator sells those swithces. www.quadovator.com
97SOLOMA's Avatar
i found in a post somewhere here a part number for a Polaris kit but like a dummy i never wrote it down, is it as simple as getting a proper switch and plugging in 2 bulbs? what wire in the pod so i use??
thanks
Old Sep 12, 2007 | 08:59 PM
If I remember right the wires under the pod are a connector with two wires in it, black and blue I think. It should be just laying in the pod, and then 2 3156 auto bulbs should work
Old Sep 12, 2007 | 09:21 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is he asking about the work lights or making them into reverse lights when put in reverse? you can add a switch and bulbs like i did, but i do beleave quadovator does make a work light to revrse light confertion.
Old Sep 12, 2007 | 10:45 PM
97SOLOMA's Avatar
basically i just want to be able to switch on lights when i want to back up, not necc. automatically, by putting the quad into reverse, i would actually prefer to have to manually switch them on!@
thanks again for the all the help thus far!!
Old Sep 12, 2007 | 11:02 PM
1967's Avatar
I have an 06 so I have the switch. I made my own circuit and relay setup to turn on the lights when I shift into reverse. Works great and don't have to fumble in the dark for the manual switch. Highly recommend the Quadovator kits if you don't want to go thru the trouble of making your own.
