rear axle hubs
Old Sep 15, 2007 | 12:21 AM
kioti's Avatar
Default rear axle hubs
does any one know if the rear hubs off a newer polaris with the 4 by 158 pattern will fit on an older 400L. i want to change the rear hubs to be able to run newer style rims.
thanks for any info kioti
Old Sep 15, 2007 | 12:48 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
what year 400. maybe you can cross ref. pn#'s
Old Sep 15, 2007 | 01:18 AM
kioti's Avatar
i belive its a 94 or 95 not sure they fit my 350L when i striped one. have a friend that has a set of rims and tires off a 500HO i want to put on my quad.
Old Sep 15, 2007 | 01:44 AM
scramblerXrated's Avatar
any hubs from a predator will fit older style polaris models, specificly gen 3 polaris. like scramblers and trailblazers. but even older models are still the same. so if your wanting the 4/156 or 4/110 rims, the splines are identical. BUT you might need a little machining off of the back side of the pred hubs, so that you can thread on the hub castle nut and use the cotter pin. but they do work. i have a pred hub set i have been using for my paddle tires, without problems.
X
Old Sep 15, 2007 | 08:45 AM
kioti's Avatar
thanks scramblerXrated thats what i needed to know.
blueandy88
Sep 7, 2020 03:11 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
snowolson
Aug 31, 2015 03:51 PM
blueandy88
Aug 31, 2015 12:42 PM
blueandy88
Aug 30, 2015 08:26 PM
