rear axle hubs
does any one know if the rear hubs off a newer polaris with the 4 by 158 pattern will fit on an older 400L. i want to change the rear hubs to be able to run newer style rims.
thanks for any info kioti
any hubs from a predator will fit older style polaris models, specificly gen 3 polaris. like scramblers and trailblazers. but even older models are still the same. so if your wanting the 4/156 or 4/110 rims, the splines are identical. BUT you might need a little machining off of the back side of the pred hubs, so that you can thread on the hub castle nut and use the cotter pin. but they do work. i have a pred hub set i have been using for my paddle tires, without problems.
X
X
blueandy88
Aug 30, 2015 08:26 PM
