03 predator 500...help
Old Sep 16, 2007 | 12:38 AM
sandman91's Avatar
Default 03 predator 500...help
i just got a 2003 predator 500 a couple days ago and rode it today for the first time in the dunes and notice that when i shifted from second to third gear it instantly bogged down and didnt have any power, then after about 5-8 seconds it will finally wind up and will run great and have tremendous power.
i had a tough time climbing hills because in 2nd gear it was revved verry high by the time i hit the top and in third it would bearly make it up because it was bogged down so low.
can anyone help me? is this normal?
Old Sep 16, 2007 | 07:42 PM
2mnyToyz's Avatar
see how you are!
<div class="FTQUOTE"><begin quote>Originally posted by: sandman91
can anyone help me? is this normal?</end quote></div>
Sounds like you're a little too fat on the needle, possibly the main jet too.
Raise the clip on the needle one position (lowers the needle) and see what happens from there. If it starts clearing it up but not quite, you have one more position to go. If it runs great at wide open throttle, your main jet may be ok, but you may consider dropping the jet one size and keeping the needle where it is. Since I haven't ridden it I can't tell how much it's bogging and where in the RPM. But don't overlook the obvious things like a clean airfilter...
Old Sep 16, 2007 | 08:35 PM
sandman91's Avatar
alright i will look in too it,
i just replaced the air and oil filter b4 i rode it.
i whent riding in the trails today and it seemed to do a little better
Old Sep 17, 2007 | 03:36 PM
PredatorSlim's Avatar
Check boots on both sides of carb, also. It may be caused by an air leak.
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Elkaholic
Sep 6, 2015 02:44 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
