Honda ATC200 help Wont Start
Old Sep 20, 2007 | 07:36 PM
M38Jeep's Avatar
Default Honda ATC200 help Wont Start
I just got a 83 ATC200 and it started for a few seconds and dies. The previous owner put a new carb on and i think the mixture and screws are all set wrong. Is there any pre set number of turns out i can set the adjustment screws on to get it started. I also pulled the plug i get spark but when pulling it gas shoots out of the cylinder. Any ideas. Thanks as always
Old Sep 21, 2007 | 11:58 PM
atcer200x's Avatar
The small pilot screw in front of the fuel bowl should be turned about one and a half turns out. You may want to remove the fuel bowl to look for something obvious---like stuck float or needle valve. If it's a Keihin carb the main jet may be a #110. Slow jet may be a #35 or 40.
Old Sep 22, 2007 | 08:52 PM
M38Jeep's Avatar
Thanks for the info im going to give it a try. The mixture screw should be 2 1/4 out is that right. Thanks for the Help
neilbedwell
Nov 10, 2018 11:02 AM
Honda Side by Sides
27
Aug 14, 2015 01:13 AM
neilbedwell
May 31, 2015 11:11 AM
1000gade
May 27, 2015 12:37 PM
lovinhonda
Jan 25, 2000 09:17 PM
