help 2000 rancher 350 es stuck in gear
Old Sep 25, 2007 | 12:28 PM
polaris man's Avatar
Default help 2000 rancher 350 es stuck in gear
i have a 2000 rancher 350 es it wont shift out of 5th gear.Tried to manual shift a nd rock but nothing and replaced angle sensor. please help
Old Sep 26, 2007 | 02:06 AM
Gimpster's Avatar
Inside the front engine cover, the shifter arm is broken.
-----gimpster-----
Old Sep 26, 2007 | 11:52 AM
how can you tell if it is broken took cover off but cant tell if its broken do u\you have to remove the clutch to get it off
Old Sep 26, 2007 | 01:46 PM
Gimpster's Avatar
Remove the oil cross over tube, clutch disengauge mechanism and remove the clutch pack center bolt. The clutch will slide ahead enough to allow the shift arm to be lifted away from the shift drum wheel, pivoted to the side and removed. Once removed flip it over and check if the tabs on the shifter arm are broke and spread apart.
-----gimpster-----
Old Sep 26, 2007 | 08:21 PM
i cant get the lock nut off the clutch looks like someone had tried to get off before any ideas thanks
Old Sep 27, 2007 | 09:03 PM
Hey just wanted to say thanks. I took off the shifter arm and it was broken almost all the way off thanks again for your help
Old Sep 28, 2007 | 02:05 AM
Gimpster's Avatar
Cool, not that it is broke, but that you found it
Sorry I have not been online much to reply
I have had a rash of blown motors in my other toy, a mini sprint. Keeping me busy rebuilding gixxers
-----gimpster-----
Old Oct 4, 2007 | 08:29 PM
i was just wondering how to adjust the clutch
scram5050
Aug 30, 2024 01:39 PM
heath legg
Jul 24, 2015 01:01 PM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
ghost civic
Jul 15, 2015 10:48 PM
sara durrant
Jul 6, 2015 05:32 PM
