Help adjusting rear shock on 06 Scrambler 500
Old Oct 3, 2007 | 06:54 PM
ck500's Avatar
Default Help adjusting rear shock on 06 Scrambler 500
I don't like how low the rear end sits on the scrambler and was thinking of adjusting the shock to a higher setting. Does this require a special tool or just some brunt? Is there anything else I can do to adjust the sag in the rear?
Thanks again for your help!
Chris
Old Oct 3, 2007 | 07:42 PM
SCRAMMYTODD's Avatar
Mine was really soft even with the rear spring cranked up, but it rode pretty good. There should be a spanner wrench in the tool kit. Make sure the threads are clean otherwise it'll be really tight.
Old Oct 5, 2007 | 02:39 PM
08Renegade500's Avatar
You can use a large pair of channel loc pliers as well if like me, you lost the spanner.
It does help the ride alot!
Old Oct 5, 2007 | 06:49 PM
97xplorer's Avatar
is there a factory setting for LBS on there?
Bratman2
Aug 6, 2022 01:42 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 13, 2015 05:11 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jkfx400P
Jul 6, 2015 10:04 AM
