Sprocket Help
Old Oct 7, 2007 | 08:32 PM
hjmdoo's Avatar
Default Sprocket Help
Hey I want to gear down my 04 400ex and I was looking at buying a 39 tooth rear sprocket instead of the stock 38. I was wondering if I would need to get a new chain for this mod. Thanks
Old Oct 7, 2007 | 09:23 PM
jetmotoracer's Avatar
go smaller in front... its alot easyer
Old Oct 7, 2007 | 09:30 PM
SMFREY's Avatar
No it is not necessary to change out the Chain
I have two 400ex Hondas
On both I have regeared Going from the origional 15/38
Went to the 14 on the front
Mine to pull the dunes easier with 22" Paddles
Wifes bike make easier for her to get over rocks trail riding
That worked so good I tried the 39 tooth on the rear
Even better
I have even gon as far as to get a 13 tooth for the front of my 400
Havent tried as yet at the dunes but will find out how it works in about 3 weeks
Still running origional length chain
Ray
Old Oct 7, 2007 | 11:50 PM
hjmdoo's Avatar
So I should go with a 14 tooth front instead of 39 rear?
Old Oct 8, 2007 | 12:54 AM
Mountana's Avatar
You won't really notice a difference just going up one tooth on rear. You'll only go from 2.53 to 2.6, but if you drop to a 14T on the engine you'll be at 2.78 ratio. Here's a handy gear calculator you can just enter your #s in and it will calculate automatically.
GearCalculator
Old Oct 8, 2007 | 12:11 PM
SMFREY's Avatar
Your biggest change will be the front sprocket
The rear sprocket is small change
The only problem with the rear sprocket is clearance
Not only ground but chain gaurd
Calculating the ratio is simple and a great tool
It would also be great if there were the same with tire diameter calculated in there
I know there is with Cars and gear ratio to tire size
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
