07 raptor 350se idle's for 10sec. and dies!
Old Oct 8, 2007 | 01:46 AM
b29fred's Avatar
Default 07 raptor 350se idle's for 10sec. and dies!
What's up with this thing. Had no problem till today! starts ok when cold , on choke maxed out, it will run and idle for a minute or so then dies .quick hit on the
throttle same choke level fires right up for only 8 to 10 sec. then dies. same procedure execpt choke has to be 3/4 close now for it to start but same result!
As soon as you give it gas even abit , it dies. Iwould try this several times , no go!
If i wait for an hour or so (cools down) it will fire up right away like nothing was ever wrong with it for only a minute or so, then the same symptom appears!Help!
Old Oct 8, 2007 | 01:56 AM
STRAIGHTUPDAHILL's Avatar
are you using a fuel filter?
Old Oct 8, 2007 | 02:22 AM
b29fred's Avatar
just bought it ! it's all stock , no more than 5 hrs use when got it. i will have to check my manual regarding a fuel filter.
Old Oct 8, 2007 | 09:02 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
you probably ran it out of gas, check your tank
Firefighter400
Oct 8, 2022 06:38 PM
slowgsxr97
Mar 18, 2022 03:40 AM
binky79
Jul 30, 2015 06:37 PM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
