Radio Controlled Winch
Old Oct 8, 2007 | 11:37 AM
Mountana's Avatar
Default Radio Controlled Winch
RadioControlledWinchThis is too cool, and only $69.00 at Harbor Freight. I ordered one for my Rubicon.
3000 LB RADIO CONTROLLED 12V PORTABLE WINCH
WIRELESS REMOTE CONTROL
Wireless remote gives you freedom of movement during vehicle recovery.
Six feet per minute @ 3000 lbs.
Two button forward/reverse remote control
Freespooling
Drop forged hook with safety retaining clip
30 ft. of 3/16" zinc plated high carbon steel cable
Ideal size for SUVs, ATV or yard tractors
7 gauge mounting plate is predrilled for installation, has cut-out for hitch ball
Overall dimensions: 8" L x 9" W x 7-1/2" H; Mounting plate dimensions: 8-7/8" x 4-7/8" x 5/8"; Weight: 18.9 lbs.
ITEM 95912-2VGA
$169.99
$69.99 Email link to a friend
Old Dec 13, 2007 | 02:15 PM
Bayouhunter's Avatar
I bought the same winch yesterday for my Rhino, 69.00 at HF. Any complaints, concerns, or praises for this winch?
Old Dec 13, 2007 | 02:26 PM
deanz400's Avatar
keep us updated ,
Old Dec 13, 2007 | 06:48 PM
LittleBill's Avatar
please do
Old Dec 13, 2007 | 10:12 PM
Mountana's Avatar
Well, I got to use this winch to pull my buck out of a nasty creek bottom this hunting season. I know it wasn't much of a load, but it saved me several hours of hard work.
Old Jan 4, 2008 | 01:22 PM
ntrsandman's Avatar
I bought one of these winches to get my sandrail into my toyhauler. It has to be backed in for space issues. Anyway, I was pissed when I first used it as I had to be two feet from it to get it to work. I replaced the battery on the remote. No change. I was just about to eliminate the remote system and hardwire it, when a friend said lets check out the antenna. Opened up the box, and found the antenna was about an inch long! We soldered a 12" 18g wire to the antenna wire and drilled a hole in the box for the wire to go through. Now it has a range of about 15 yards or more! It pulls my rail up the ramp and into the trailer slowly but surely. It had some strain when the tires were being pulled over the lip of the door and up the ramp. But it did the job. I will carry an extra remote battery as there is no other way to activate the winch and I will be careful with the remote as a replacement may not be easy to get if it is broken.
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
cboler9
Sep 24, 2015 08:35 PM
toonces
Sep 9, 2015 03:28 PM
chewy78
Sep 8, 2015 10:37 AM
