hawkeye valve adjustment
Old Oct 9, 2007 | 12:31 AM
coolhandnts's Avatar
Default hawkeye valve adjustment
[img]i/expressions/beer.gif[/img] can anyone tell what the valve setting's is on 2006 hawkeye and the right way to peform this adjustment
thank's for any input
Old Oct 9, 2007 | 11:52 AM
00XJ's Avatar
I know on the '07 the intake and exhaust are set to .006". I'm sure the '06 is the same. You remove the valve/cam cover, loosen the locking nut on the adjustment stud on the end of each rocker arm, and set the clearance using a feeler gauge. While holding the adjustment stud so it can't turn you tighten the locking stud. It actually takes more time to remove/replace the cover than it takes to set the valves.
I believe it took a 5mm and 6mm wrench to set the valve clearance.
Old Oct 9, 2007 | 03:30 PM
do i remove the plug on th right side and find the t mark {this would be top dead center compresion stoke}
Old Oct 10, 2007 | 01:22 AM
00XJ's Avatar
The manual states to make sure the cam lobes are pointing down. Really no need to be exactly at TDC, just that the valves are fully closed.
I just removed the spark plug, and used the recoil starter to turn the engine over until the cam lobes were down.
Old Oct 10, 2007 | 08:03 PM
thank you alot !!
fordfaithful21
Dec 7, 2015 05:52 PM
Jason Richards
Sep 4, 2015 06:17 PM
snowolson
Aug 31, 2015 03:51 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
Sportsman850
Jul 31, 2015 04:25 PM
