Honda TRX350 Won't Start
I have a 90 Honda TRX 350 that won't start. It was working fine then It sat for a few months and it turns over but won't kick. It seems to be getting fuel but no go. Is there anything common I should check for? It doesn't seem to be getting spark. Just thought I'd check. Thanks.
Mac
Mac
I would remove the spark plug cap from the wire and check the spark if still no fire move back to the ignition coil. On most of these the wire and the cap screw on to a pointed pin check these for corrosion. Also may want to try another spark plug.
Honda Side by Sides
27
Aug 14, 2015 01:13 AM
