1995 polaris scrambler400 no spark . please help
Old Oct 9, 2007 | 05:52 PM
poscrambler400's Avatar
Default 1995 polaris scrambler400 no spark . please help
i have no spark , is there a way i can test my coil , to make sure its good . any ideas would help . i have a ohm / volt meter for testing . i do not have a book on the bike so i have no idea on any specs . thanks matt
Old Oct 9, 2007 | 05:54 PM
94harley's Avatar
Remove the black wire for the reverse limiter first. Check for spark. Any change?
Old Oct 9, 2007 | 06:02 PM
wheres the black wire ? there is a blue wire runing into the coil thats the only one that goes to it . this bike did get stolen at one time so there is no key switch , i have the two big red wires twisted together . then there are a black wire and a brown wire that is hanging around , i aussume these 4 wires went to the key on off switch , one for the ground and other for power . that sound right to you ?
Old Oct 9, 2007 | 06:10 PM
i have the coil in my hand is there a way to check the coil with my ohm meter ?
Old Oct 9, 2007 | 09:39 PM
anyone ?????
Old Oct 10, 2007 | 06:33 PM
look i really need to get this thing running , i dont want to have to pay a shop to fix something as easy as a coil or whatever . i just got this bike from my parents who had it stollen from there house . it does not have a ignition switch anymore so i have to twist the wires together . it did run until the starter bedix broke , then some kids tryed steeling it but could not get it to run since the starter was broken , and the pull start did not work also . so i got the starter fix now it does not have any spark . thanks for any help .
Old Oct 14, 2007 | 05:07 PM
BUMP .........................***** THIS FOURM !!
Jmuddin284
Jan 19, 2026 07:16 AM
Coryco
Jul 6, 2015 07:30 PM
jettman
Jul 6, 2015 12:16 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
D-Hagz
Jul 4, 2015 02:19 AM
