What is the difference between the air filter and full system air filter
Old Oct 10, 2007 | 12:40 PM
q8y_cool's Avatar
Default What is the difference between the air filter and full system air filter
hi there
some ppl say install air filer from K&N and other say install the full system of air filter...
so what is the difference between them by how to install and by parts and by power
thank you guys
Old Oct 10, 2007 | 05:17 PM
scootergptx's Avatar
Supersock
Hired Gun!
Replies removed.
Let's try to be a little more helpful here.
Not sure what you mean by full system air filter. Running without airbox, or adding an filter lid?
Old Oct 10, 2007 | 05:31 PM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
I'm pretty sure their talking about a Prodesign system which has it's own intake for the UNI filter to clamp around. It's a great system which is more secure than the stock filter. I would never run a K&N on a YFZ, check out the link
http://www.motoworldracing.com...r-Filter-kits-ATV.html
q8y_cool's Avatar
they say the full system is running without the air box and use ( air filter and pipe from the air filter to the engine with some of small filter in the pipe )
like ESR full system of air filter and full custom
the only air filter is like only K&N filter with the yfz air box or without the yfz air box
now i want to now what is the best power and good for the engine
thank you
Old Oct 10, 2007 | 05:33 PM
q8y_cool's Avatar
thank you very much CamoKodiak450 for the link [img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 10, 2007 | 05:47 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
i would never run a K&N on any quad.... ESR's setup on my buddies 250r when they sent him a bunch of parts was just a bent peice of pipe for the filter
Old Oct 10, 2007 | 06:00 PM
STRAIGHTUPDAHILL's Avatar
LESS RESTRICTION=BIGGER HOLES=MORE DIRT GETS THROUGH
Old Oct 10, 2007 | 06:13 PM
Speedy2222's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: STRAIGHTUPDAHILL
LESS RESTRICTION=BIGGER HOLES=MORE DIRT GETS THROUGH</end quote></div>
EXACTLY
Old Oct 10, 2007 | 07:32 PM
bberck's Avatar
There are different set-ups depending on what you want.
1) You can either leave your stock intake (cone shaped peice inside your filter) and just replace the filter. Really not much if any gain here.
2) You can go with a intake/filter set-up like linked above that removes the restrictive cone and allows more air in with a new filter.
3) Another option on the 450 is to go with a set-up that replaces the filter,intake and intake tube that runs to the carb.
You can run any of these with either types of filters although Im not sure you can find the 3rd with a foam, you would have to find one that fit.
I have ran both UNI's and K&N's and have never had any issues from either.
Old Oct 10, 2007 | 10:44 PM
q8y_cool's Avatar
thank you guys for the tip
i see the ESR full system ( air filter ) came with filter and pipe and thy say we will remove the original filter - pipe - air box...
than thy will install the ESR full air system without the air box and thy say we will install big jet nit to me come work good and yoshimura full exhaust system are this all good for my ATV its yfz 450
and thy say you can install (FULL CUSTOM) full air system or (ESR) full air system
thy say the (ESR) give 5 hp and the (FULL CUSTOM) give 7hp are that real!!!
