660 Raptor Hop up's
Old Oct 11, 2007 | 05:08 PM
raptortn's Avatar
Default 660 Raptor Hop up's
After I get the bug work out.
Was debating on a stage 1 cam or the aftermarket filter and oil box. Anyone have any insight.
Riding style - Trail riding / Woods racing
Setup as of now - stock other than shock, using my old axis setup that came from the banshee, lower the whole ATV 2" thru some bike bars on it, sit's about 1/2 lower than a 400ex
Old Oct 11, 2007 | 09:51 PM
Raptor450's Avatar
If you don't have a pipe yet, I would suggest getting one of them first. Curtis Sparks sounds wicked and performs excellent on the 660. Filter would be next.
Old Oct 11, 2007 | 09:59 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
letm e know if u want to sell the axis shocks i might buy em
Old Oct 11, 2007 | 11:40 PM
Turtler's Avatar
You want more performance, work on new air filter intake, rejet and exhaust for starters. Do that before you bust into the motor. I like the performance of my Sparks X6 exhaust.
Old Oct 12, 2007 | 10:55 AM
raptortn's Avatar
Has the Whitebros E-Series Exh. using stock headpipe seen the pro design airfilter what do you recommend.
drop one tooth on front sprockets was debating about going up 2-3 in the rear, would like to see 3rd come into play more than it does.
Old Oct 28, 2007 | 01:07 PM
skramblr's Avatar
My recommended order of upgrade:
1) Air Intake - Proflow or GYTR setup with the billet aluminum filter adapter so your can remove the airbox lid and then rejet
2) Bore the head - add a 102mm 11:1 compression piston
3) Then add Stage 1 cam
Old Oct 29, 2007 | 01:42 AM
maddog56's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: raptortn
Setup as of now - stock other than shock, using my old axis setup that came from the banshee, lower the whole ATV 2" thru some bike bars on it, sit's about 1/2 lower than a 400ex</end quote></div>
The stage 1 cam isn't going to do much when the machine can't breathe. Get a clamp on GYTR or Pro-Design filter kit first. The next step would be an aftermarket exhaust, but if for some reason that's not an option for you then the stage 1 would be the next step.
Cylinders get bored, heads get ported. I'm sure that's what you meant, just wanted to clear things up.[img]i/expressions/face-icon-small-cool.gif[/img]
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
