300ex no spark
Old Oct 13, 2007 | 09:46 PM
Dole's Avatar
Default 300ex no spark
Besides a new plug what part if any is know to go out on a 300ex. What part should I check 1st. Do you know where I could find used 300ex parts?
Old Oct 14, 2007 | 07:20 PM
300exStroked's Avatar
theres a reverse and neutral switch in the right side casing that could go bad. Possibly just check the wires that are running to it in front of where the reverse cable hooks up. Theres a little black cover on that, unplug them and check continuity on those. Could also be a bad CDI box.. easiest way to check that is take one from a running 300 and swap them out. Or, the coil may be bad. Check the reverse/neutral switch wires first. I've got extra CDI's if you realize thats whats wrong.
Old Nov 2, 2007 | 11:35 PM
Dole's Avatar
Thanks for the info. For some reason I have not been able to check this message. I want to thank you for your reply and sorry for the delay. I will check out and try your suggestions. I am having a problem putting the 300ex into reverse. About how much would your CDI cost? Thanks again
Old Nov 3, 2007 | 12:41 AM
send me an email..
bradfoal@email.uc.edu
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
