Somebody must know
Old Jan 5, 2001 | 11:14 PM
warrior3443's Avatar
Does anybody know the stock jets on a Yamaha Warrior. Mine is a '96. Does anybody know what size i should go to with a pipe and airbox lid holes? Thanks a lot.
Old Jan 6, 2001 | 11:08 AM
WildTurkey's Avatar
In stock form, a Warrior comes with a #145. You should go up one jet size at a time. So, the next size you'll try would be a #147.5 jet. After you install it, throw in a new plug. Let quad warm up to driving temps, then read the plug.
Old Jan 6, 2001 | 11:25 PM
93warrior's Avatar
wildturky, Maby its just mine but i took out my old jet, (122 i think) And the K&N paper said w/ after market pipe and stock airbox lid put a 136 in. thats what i did. for AM pipes and cut up air box lid put a 145 in. not trying to pick a fight but thats the way it was.
Old Jan 7, 2001 | 03:23 AM
99WarMachine's Avatar
93Warrior, the Warrior has used the exact same carb from 1993, until now. The bottom of your main jet should have the size stamped on it. If it's stock, it IS a 145. The information on the K&N sheet is wrong.
I ride at about 2500 feet, and I was able to successfully move up to a 155 main jet, after installing a new pipe, K&N filter, and removing the airbox lid.
Old Jan 7, 2001 | 04:34 AM
redyam350's Avatar
It depends on temp & altitude & if you take the main out it will be writen on it in small numbers.
Old Jan 7, 2001 | 07:59 AM
dstevens's Avatar
my 95 had a 122 in it, it hase been stock since it came from japan
Old Jan 7, 2001 | 02:48 PM
redyam350's Avatar
Is that why mine came with 4 sets of main jets for different altitude & temp. Here in CA you can drive up to the moutains & have to rejet unless you have fuel injection
