Swing Arm Bushings Scram 500
Old Oct 14, 2007 | 11:50 PM
rescramble's Avatar
Default Swing Arm Bushings Scram 500
Anyone have an easier way to change out the swing arm bushings transmission side? It is a hassle having to take off the clutches and back belt cover. Something more simple?
Old Oct 15, 2007 | 12:30 AM
03scrambler500's Avatar
there isn't any other safe way to do it becuase you have to pull everything apart and make sure its all clean in order to make sure the new red loctite that you have to apply will work right. the clutches really aren't that hard to pull off and you will probably save time by doing that than fighting the back cover. i would pull everything apart and if you have any other questions about how to get the cluthes off just ask.
Old Oct 15, 2007 | 12:55 AM
scramblerXrated's Avatar
the fastest way to do it is pulling the clutches. you can have the clutches off and have access to the swingarm bushing in 15 minutes with the right tools. a primary clutch puller is a must own if you ride a polaris.
X
Old Oct 15, 2007 | 07:46 PM
rescramble's Avatar
10-4 I have done this once before with a borrowed pulley tool. i no longer have access to it. Guess i will order one. Thanks for the help!
Customer Service #1
May 15, 2020 08:46 AM
fd24
Jan 16, 2019 08:59 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 19, 2015 06:34 PM
