Gas Gauge help
Old Oct 16, 2007 | 12:28 AM
reelfootoutlaw's Avatar
Default Gas Gauge help
I have a 2005 sportsman 800 the digital gas gauge quit working this weekend. It does not show up when the atv is cut off and back on. Thanks for the help.
Old Oct 16, 2007 | 07:58 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
maybe a bad sending unit in the tank so it wont read the amount.
Old Oct 16, 2007 | 01:50 PM
I dont know its like nothing on the gas gauge shows up like it does not have one at all. I thought there might be a fuse or a wire that got pulled loose. I dont have the owners manual for the ATV i may try to fill the tank up and see if that does anything.
Old Oct 16, 2007 | 08:33 PM
craftyboy's Avatar
I have the exact problem on my 2005 sportsman 800. The LCD that used to display the fuel level is blank. This occured after bumping a tree, so I assume a connector got jarred.
Old Oct 16, 2007 | 09:08 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the book says you have to drasin tank and remove it to test it. w. it empty it should read 5 omhs and 90 ohms when full if you get an erratic reading then its junk and have to replace the whole thing. you use the violet/white and brown wires in the harness to check.
Old Oct 16, 2007 | 10:03 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Mine was like that when I took it home from the dealer.............Was not the sending unit ......But I forget what they did.........Did not take them long...........I got it fixed with the first service...........I try to remember for you..........Caper.........It will come to me..........LOL....getting old I guess....
Old Oct 20, 2007 | 05:39 PM
craftyboy's Avatar
My wires are red violet and brown (2005 800). The brown is the ground. Anyone know which ones to test?
mtdewmn
Jan 19, 2017 12:13 PM
panicmanic
Sep 20, 2015 05:54 PM
Logan Collins
Sep 5, 2015 08:03 PM
bradco
Aug 21, 2015 08:11 PM
Cantbuytime
Aug 17, 2015 06:33 PM
