03 Scrambler 400 stuck in reverse.
Old Oct 18, 2007 | 11:27 PM
IamBIGGUN's Avatar
Default 03 Scrambler 400 stuck in reverse.
I'm looking into buying a used 2003 Scrambler 400 that is stuck in reverse. Has anyone run into this problem? I'm hoping to get some ideas on what kind of things I should be looking for to trouble shoot the problem before I make an offer.
Thanks,
Kevin
Old Oct 19, 2007 | 01:30 PM
duffus's Avatar
does it start moving when it is running @ idle? Most likely it is a stuck cog inside the tranny -- try rolling it and shifting it into neutral.
Old Oct 19, 2007 | 01:42 PM
TLC's Avatar
TLC
Disconnect the linkage rod at the shifter and see if you can push or pull the rod by hand to get it in and out of gear. If so your linkage rod has to be adjusted.
Old Oct 19, 2007 | 09:37 PM
IamBIGGUN's Avatar
Thanks. I'll try to get a better idea when I go to get it. I have to wait a week before I have any time off........I hope it doesn't sale first.
Kevin
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
Matt123
Sep 29, 2015 01:29 AM
Jackg17
Sep 26, 2015 09:30 PM
