2006 scramler 500 cutting out
Old Oct 19, 2007 | 09:24 PM
gsmith9898's Avatar
Default 2006 scramler 500 cutting out
My new to me scrambler 500 was running fine than started missing real bad when you give it gas. Does it sitting steel or under a load. I changed the fuel filter and added some different gas, but still no luck. Any ideas?
Old Oct 19, 2007 | 11:16 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is it acting the same way as it would if reverse if you didnt push the override in? just wondering maybe the override is starting to mess up? or is it more a carb issue where its missing from lack of fuel.
Old Oct 19, 2007 | 11:21 PM
dwhst9's Avatar
Have you checked the rocker lash?
Old Oct 20, 2007 | 09:17 AM
gsmith9898's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
is it acting the same way as it would if reverse if you didnt push the override in? just wondering maybe the override is starting to mess up? or is it more a carb issue where its missing from lack of fuel.</end quote></div>
No its spitting and sputtering. Its gotta be the carb or electrical the way it sounds. How do you get to the plugs and wires?
Old Oct 21, 2007 | 01:09 AM
MOJeepr's Avatar
As stendori said, is it similar to being in reverse without the override pushed? Mine was doing that when water would hit the connector to the reverse safety swich. At first, I waterproofed the connector, but then later I just disconnected the switch altogether.
Old Oct 21, 2007 | 02:30 AM
gsmith9898's Avatar
no its not like the reverse. Its just coughing and sputtering. You can be in neutral and give it full throttle and it will cut out real bad.
Old Oct 21, 2007 | 02:58 AM
scramblerXrated's Avatar
you have a clogged pilot jet. the jet that controls the fuel from idle to 1/4 throttle
remove the carb and clean out both jets. (main and pilot) its actually a good idea to bump the pilot jet up a size while you have it apart...stock is #40 i bumped mine to 42.5 and it made a big difference in throttle response...
X
Old Oct 21, 2007 | 10:53 PM
gsmith9898's Avatar
No i haven't somebody else told me to check that. It is a 2006 with very low hours. Never thought about valves.
Old Oct 21, 2007 | 11:53 PM
ftwflh's Avatar
Hey sounds like a dirty air filter to me.Mine does the same thing when the pre filter stopps up.That is why I carry a spare outerwears
Old Oct 22, 2007 | 09:08 AM
gsmith9898's Avatar
No I cleaned the filter. I put some carb cleaner in the tank and that seems to have made it worse.
