Sportsman 4 wheel Drive issuse
Old Oct 23, 2007 | 09:34 AM
edmo500's Avatar
Default Sportsman 4 wheel Drive issuse
My Front left hub will not lock in like it is supposed to. I noticed it stopped spinning while I was in the mud a couple weeks ago. Last weekend I ran it with the tires off of the ground, it kicked it when the wheeler hit about 20 m.p.h. I pulled the hub apart and everything looks fine in there. All bearings look good. Any idea what my problem might be? I have a 96 sp 500
Old Oct 23, 2007 | 02:57 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is it getting any power to the wheel?
Old Oct 23, 2007 | 03:02 PM
edmo500's Avatar
yeah there is power. The 4 wheel drive wont engage until high speeds. Once its engaged it will stay engaged. It also has a tough time disengaging. (have to put in neutral or reverse and run for a while to disengage) the good side engages at idle and disengages when 4WD button is off.
Old Oct 25, 2007 | 08:23 PM
Polaris500HO4x4's Avatar
Make sure the plate in the hub is not warped. it needs to be perfectly straight
Old Oct 25, 2007 | 08:31 PM
edmo500's Avatar
I think that may be the problem. I noticed it was a little wore on the magnet side. I am in school and only go home on weekends, so I will have to check it out this weekend! thanks!
Old Oct 25, 2007 | 08:59 PM
outlaw77's Avatar
had a problem like that with my scrammy it was the ameture (not sure of correct spelling) but it was an easy fix and cheap also.. i let mine go to long and ended up snapping a yoke..
Old Oct 25, 2007 | 10:49 PM
edmo500's Avatar
yeah I will check that out, it wasnt too worn down. The "ears" looked good and everything but the back side looked a little worn out, the black coating/paint was worn off and I can feel a rough edge with my fingernail. I really hope thats it! I can hole the armature close and push the button and the magnet pulls the armature tight...
bzdok1234
30
Feb 23, 2016 01:55 PM
coldnorthpol
Jul 14, 2015 11:22 PM
D-Hagz
Jul 4, 2015 02:19 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
