Trail Boss - Stall
Old Oct 23, 2007 | 03:31 PM
AZZukR450's Avatar
Default Trail Boss - Stall
I have a 2000 Trail Boss 325. I put the choke on to start it, while it is warming up if I take the choke off, it stalls. So I keep the choke on. After about a minute of running with the choke on, all the sudden it will stall for no reason. Now it will not start with or without the choke. Get this... if I take the gas cap off and blow into the tank (formng a seal with my lips - on the inside...), now with the choke off it will start right up and she is good to go. This happens every time if it is cold. Sounds like a vacume leak, but not sure where to go from here.
Old Oct 23, 2007 | 03:35 PM
scootergptx's Avatar
Supersock
Hired Gun!
Check the vent hose on the gas tank for kinks.
Old Oct 23, 2007 | 04:09 PM
deanz400's Avatar
had some hard starting and stalling issue ,I cleaned the carb and made sure all the passages were open ,and it seemed to help a lot .
Old Oct 23, 2007 | 04:11 PM
Supersock
Hired Gun!
And being a 2000, you might want to get a new fuel filter. I just got a cheap inline one from the parts store.
Old Oct 23, 2007 | 04:35 PM
AZZukR450's Avatar
Thanks for ALL your input... I went out and took the plastic off. The gas tank vent hose is fine. I fired it up with the plastic off and the exact same thing happened. Sooooo, I turned the petcock to reserve and it fired up!!! I am going to let it completly cool down and try starting it tonigh with it on reserve.
I purchased this quad new in Nov 1999 and it has been extremely reliable. I have rolled it at least 4 times and it went solo down a mountain. Replace broken parts and she fires right up. Battery and starter are the only thing that needed to be replaced.
Old Oct 23, 2007 | 04:39 PM
Supersock
Hired Gun!
Just replaced a few things on mine after a roll. While I had the tank and plastic off, I changed out all the fuel lines. Really need to take the tank off and give it a good cleaning too. Surprising how much of a beating mine has taken and still runs great.
Old Deer Hunter
Sep 2, 2015 01:39 AM
Anomers
Aug 16, 2015 11:06 AM
Backwoods_badass
Aug 1, 2015 10:25 PM
Gnuters
Jul 19, 2015 10:03 AM
