96 400 sportsman electrical?
Old Oct 28, 2007 | 10:14 AM
Timmerman's Avatar
Default 96 400 sportsman electrical?
just bought a 400 sportsman and i have no lights only a awd light that i can switch on and off. Is there any fuses in this? How do i check the front light? Do i have to remove the plastic or just un screw the light adjustment screws.
Old Oct 28, 2007 | 10:53 AM
hoytultratec's Avatar
you have to remove the plastic for the center light its 4 screws check all the bulbs.....if these machines are run with a dead battery it will burn out the light bulbs that what i was told and even read it on here, might be the reason you have no lights .
just a thought
hoyt
Old Oct 28, 2007 | 10:54 AM
94harley's Avatar
No fuses. Remove the headlight pod, not the adjustment screws. Check for voltage at the connector, probably just needs a bulb. Make sure it has a good battery in it. If you use the pull start to start it, and the battery is bad the voltage regulator sends out 15, to 16 volts to get the battery back up to where it supposed to be and that is too high of voltage for the electrical components on the unit. Rap it up and bulbs start blowing out, cdi's and reverse limiters can get messed up etc.
Old Oct 28, 2007 | 06:12 PM
Timmerman's Avatar
Thanks for the info. I was wondering why i was getting about 17 to 19 volts on the meter. Looks like i will be buying new bulbs they are all burnt and a new battery. I have a new battery in my 250 trail boss but if i switch i guess the 250 will put out high volts.
Old Oct 28, 2007 | 08:14 PM
you can change batteries that voltage you got was with a dead battery it was charging the battery wich was shot so all them volts went to the lights and pow.
Old Oct 29, 2007 | 06:41 AM
Timmerman's Avatar
If i put the dead battery in the 250 trailboss it would blow the bulbs in it? The battery is shot won't take a charge.
Jmuddin284
Jan 19, 2026 07:16 AM
Big bousse
Sep 26, 2015 10:42 AM
sweaver
11
Aug 18, 2015 03:47 PM
raceware
Jul 30, 2015 06:59 AM
ranvette
Jul 4, 2015 06:13 PM
