Yamaha Big Bear questions
Old Oct 29, 2007 | 12:09 PM
hunter991's Avatar
Default Yamaha Big Bear questions
I just purchased a 2003 Yamaha Big Bear 400. The quad is in very good shape.
I am just inquiring about the reliability of this model. Any problems that have been brought up or is this a pretty solid ATV?
i am going to use it to plow some snow, light trail riding and general yard work...
Anything i should have looked at?
Old Oct 29, 2007 | 10:33 PM
kurt1011's Avatar
cograts! i think it is a very reliable quad - should serve you well for many years. This is a great site for info on maintenance and mods. Be safe and enjoy the new ride.
Old Oct 29, 2007 | 11:46 PM
jleo's Avatar
I have the same quad, It seems it has constant problems, but I beat on it alot and im sure you'll have problems with any quad if you beat on them. I had to have the engine rebuilt a year ago at only about 800 miles. The cheap 4wd switch button broke. It leaks front diff. fluid because the bearings inside are bad. The rear brake drum went bad and would freeze in the winter so I totally disconnected it so I dont have rear brakes. Those are the problems I can think of right now.
Old Oct 30, 2007 | 09:16 AM
hunter991's Avatar
This one seems to be solid. Plan to put a plow on it. Got a question, is installing a plow hard to do?
I have a kodiak that has a plow and i have two mounting holes under the foot well. I don't have these on the Big Bear. How do you attach the plow ? the BB has a winch too.
Old Oct 31, 2007 | 08:00 PM
AZadventures's Avatar
Our 2003 Big Bear has been running perfect for over 3500 miles, and never a problem. This is Arizona so we virtually never see any mud or water, but we do see rugged, rocky, and dusty trails, and have ridden hard with temperatures over 110 degree's without a studder. My only complaints are that it can be a bit tippy, and could use a high range as the top speed is a little low, but overall I can't complain.
Old Nov 1, 2007 | 08:35 AM
ctateusa1's Avatar
The big bear is a great quad I have known a lot of people with them and rarely a complaint here in arkansas and we have just about every kind of ridding.
Old Nov 1, 2007 | 07:39 PM
jleo's Avatar
To attach the plow, I have a mounting plate.
Two U-bolts go over the frame of the big bear (1 on the left, 1 on the right), then the mounting plate has holes for the U-bolts to go into and it is tightened with nuts.
Cole Hadden
Jun 15, 2025 09:05 AM
Ean
Dec 19, 2022 08:48 AM
toonces
Oct 16, 2019 12:11 PM
tporath
Jul 11, 2015 12:31 PM
Jul 7, 2015 11:00 PM
