Carb Help
Old Oct 30, 2007 | 02:29 PM
acklinb's Avatar
Default Carb Help
The 07 grizz 450 I just bought is running extremely lean. The plug is white. The dealer reluctantly moved my jet from a 131.3 to 135 with no difference. I plan to do the job myself. I would like to know what jet size you guys are running so that I can get in the ball game. Also any other tuning info would be appreciated. Also where can I find some info on this BSR 33 carb. Mikuni dosen't even list it. Thanks
Old Oct 30, 2007 | 02:36 PM
STRAIGHTUPDAHILL's Avatar
Default Carb Help
are you running unleaded gas?
Old Oct 30, 2007 | 02:43 PM
acklinb's Avatar
Default Carb Help
Yes 91 Octane
Old Oct 30, 2007 | 03:34 PM
Default Carb Help
unleaded gas looks whiteish on plugs when running normal..are you having any other symptoms
Old Oct 30, 2007 | 04:51 PM
hondabuster's Avatar
Default Carb Help
If your airbox and air filter are stock, and your exhaust is stock, then its jetted fine.
Old Oct 30, 2007 | 10:51 PM
acklinb's Avatar
Default Carb Help
When a plug is a brown paper sack type color is when you have it tuned in. A white color means lean. There is also no top end. At 3/4 throttle to full throttle there is no gain. I realize that yamaha sets their machines very lean to meet EPA standards but this is to lean. I am figuring probably a 150 jet but I don't want to spend a lot of money buying jets I can't use. I just need a good starting point.
Old Nov 11, 2007 | 10:16 PM
270quadsportguy's Avatar
Default Carb Help
jets are only round 5 bucks each
Old Nov 12, 2007 | 01:58 AM
ezplumore51's Avatar
Default Carb Help
[img]i/expressions/face-icon-small-happy.gif[/img]I would go a-little big-rich and then jet down,to rich=fouled plug,to lean=siezed motor, not good when jets are about $5.00 each, get a few of them and set it the way you want, Lite to a darker brown=OK. James
Old Nov 12, 2007 | 02:21 AM
Honeyduck96's Avatar
Default Carb Help
Extra jets are good to have on hand for future upgrades (pipe, air filter...) anyway.
Old Nov 12, 2007 | 03:08 PM
toddmh's Avatar
Default Carb Help
<div class="FTQUOTE"><begin quote>Originally posted by: acklinb
Yes 91 Octane</end quote></div>
way to high run the regular 86 or what ever your state has..I don't know the manual for your machine but I bet 91 Octane is way to high..
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
