Rear Axle Seal
Old Oct 30, 2007 | 07:49 PM
Cuttin_up's Avatar
Default Rear Axle Seal
I replaced a CV boot on the outside rear wheel a week ago. Since then I have had a pretty bad leak of rear diff fluid from what seems to be coming from the rear axle seals. What's weird, is that it leaks on both sides of the diff. Could both of these seals been damaged when I replaced this boot or is this another problem? This bike is brand new....I only have 150 miles on it. Need some direction....Thanks.
Old Oct 30, 2007 | 07:50 PM
STRAIGHTUPDAHILL's Avatar
if it's brand new take it back and tell them to fix it or shove it
Old Oct 30, 2007 | 10:22 PM
Cuttin_up's Avatar
yea I agree, but if it is something simple that I can fix myself and not have my bike tied up in the shop for 2 weeks I would prefer that.
Old Oct 30, 2007 | 11:58 PM
cbacon's Avatar
It sounds like it the seals.They are easy and cheap to fix.I use to have a grizzly 660 and i had to change them quite a bit.Just make sure you do change them and make sure the Diff. Fluid is clean. If it gets bad it gets real thick and is a pain to change.I have also had it get so bad it ate up all my gears and i had to replace the whole rear end.It wasnt fun or cheap.
Old Oct 31, 2007 | 01:39 AM
just be warned that if you fix it yourself. down the line if it's something serious you are screwed on your waranty
1986Vmax540
Jul 9, 2021 09:53 PM
STLyamwar
Jul 25, 2020 04:44 AM
bigred20653
Aug 31, 2015 12:41 PM
DeFox500
Aug 14, 2015 05:59 PM
Rider252
Jul 6, 2015 03:37 PM
