96 400 sportsman knocking noise?
Old Oct 31, 2007 | 07:27 PM
Timmerman's Avatar
Default 96 400 sportsman knocking noise?
The knocking noise seems to be coming from pull start area but hard to tell. When i rev it up the noise seems to get less. The bike has lots of power, well for a two stroke 400. I just bought the bike and was wondering if i should be worried. Is this knocking normal, I see some other have had knocking for a long time without any problems. The compression seems fine. I see a nut on the top of the pull start is this to fill some fluid? I have a manual comming from ebay but it is for a 2001 this is a 96, probably won't do me much good.
Old Oct 31, 2007 | 09:38 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it doesnt sound like its coming from the clutch cover does it? just wondering maybe a clutch issue.
Old Oct 31, 2007 | 10:29 PM
ftwflh's Avatar
Pull the primary clutch off and I bet it stops.When the clutch buttons get worn the rattle and it echos all over.
Old Oct 31, 2007 | 11:04 PM
TLC's Avatar
TLC
Mines is a 4 stroke and that hole on top of the pull start is to look at the timing mark.
Old Oct 31, 2007 | 11:46 PM
hoytultratec's Avatar
mine makes the same noise it does sound like it comes from the recoil area and dissapears when you give it gas...im not to worried.
Old Nov 1, 2007 | 06:17 AM
Timmerman's Avatar
Thanks for the info. I will look at the internet to see what these clutch buttons look like. It is a little anoying but i can tolorate it after all its a noisey 2 stoke anyway. Hey
hoytultratec has yours been like this for a while?
Old Nov 1, 2007 | 06:40 AM
since i bought it a year ago if you figure it out let me know what it is.
Old Nov 1, 2007 | 07:18 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if ftwflh and myself are right then you want to check it out and replace the worn parts if there real bad. if the clutches has alot of miles then they might be worn some. just a thought.
stendori's Avatar
Super Quad Patrol
I'm watching you!
Old Nov 1, 2007 | 10:17 AM
TLC's Avatar
TLC
<div class="FTQUOTE"><begin quote>Originally posted by: hoytultratec
mine makes the same noise it does sound like it comes from the recoil area and dissapears when you give it gas...im not to worried.</end quote></div>
I have that too, I think its the Bendix drive, the two holes each end of the drive fit into are not a tight tolerance and the bendix viberates.
