i know a way to to get it to start easyer in cold weather
Old Oct 31, 2007 | 10:05 PM
mudder234's Avatar
Default i know a way to to get it to start easyer in cold weather
anyones atc starting hard in the cold weather i have a suggestion take off the defenders a and stick a heat lamp or trouble light on the frame pointed toward the block wait about 30mins. to 2hours and it should starte as if it were summer
if you have a better idea let me know.
it worked the handle bars are staight yay
Old Nov 4, 2007 | 08:19 PM
SMFREY's Avatar
Default need help
How bad are the bars bent
If not bad then get a bar and straighten
If tacoed Replace
Old Nov 7, 2007 | 08:14 PM
-JR-'s Avatar
If your trike is hard starting in cold,do what I did .
Raise your niddle jet by lowering your clip.
Makes a big difference !
Second choice I did before making the carb adjustment was use starting fluid!
Old Nov 14, 2007 | 01:28 AM
250sxfreak89's Avatar
Buy a 20 dollar ceramic heater. Put it up close to the block and turn it on. Heats it up pretty dang good.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Big600twin
Jun 10, 2015 03:01 PM
sae156
1) Engine problems..
Jun 3, 2015 01:45 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
