Engine trouble
Old Nov 1, 2007 | 10:32 PM
gtmpsgt's Avatar
Default Engine trouble
I have a 2003 polaris 700 twin. The motor vibrates so bad it keeps wearing out the exhaust socket gasket. It will only idle with the choke on a little. When it dies it will start right back up. And it will backfire after being reved up. Also the exhaust manafold will become cherry red at times. The machine still has plenty of power. I have talked with two mechanics and have two different answers. 1. the rings are shot and 2. The jets are pluged
Can anyone help
Thanks
Old Nov 1, 2007 | 11:48 PM
Doctorturbo's Avatar
GOT BOOST!
Number two is correct. Or let me say your real lean for some reason. Could be a plugged jet, could be a bad carb boot..................Could be lots of things.............but your lean.
Old Nov 2, 2007 | 12:06 AM
gtmpsgt's Avatar
Thanks for the help.
Old Nov 2, 2007 | 12:15 AM
GOT BOOST!
No problem, let use know what you find out.
Old Nov 2, 2007 | 12:38 AM
94harley's Avatar
Check your motor mounts(especially the lower front) Put a pry bar under the motor and lift up. See if the metal and rubber have separated.
Check the intake boot for cracks(happens a lot) like Doctorturbo said.
Old Nov 2, 2007 | 07:36 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i know the 800's were famous for breaking the engine mounts as well.
manuelrivera
Aug 8, 2015 04:34 PM
cornermike
Jul 30, 2015 06:37 AM
heath legg
Jul 24, 2015 01:01 PM
ltrmc02
Jul 22, 2015 04:50 AM
Desimation2k8
Jul 17, 2015 12:37 AM
