Pipes and silencers on Warrior
Old Jan 7, 2001 | 07:46 PM
WarriorWoman's Avatar
What are the best pipes and silencers to get for a '97 Warrior? I've heard that the White Bros. are pretty good. Does anyone have a White Bros pipe on their Warrior? Are you happy with it? Does anyone have another brand that theyre happy with?
Old Jan 7, 2001 | 08:03 PM
Screamin96's Avatar
My friend had a white bros. on his 98 warrior. It is VERY loud. He got rid of it about 2 months later cause there wasnt really any noticable performance increase. 4strokes are not like 2 strokes when it comes to aftermarket exhausts.
Hey check out https://atvconnection.com/ the best site on the net for ATV information.
Old Jan 7, 2001 | 09:10 PM
WarriorSki's Avatar
I have the DMC Dual Barrel exhaust system for my 2000 Warrior (pipe, silencer, spark arrestor). I love the sound and their is a noticeable improvement in performance across the low-mid-high ranges. You will need to rejet, and I would recommend adding a Pro Flow kit with K & N air filter at the same time. I am pleased with this set-up on my ride. Next steps are a mild cam, valve springs and a better carb. Good luck!
Old Jan 7, 2001 | 09:26 PM
99WarMachine's Avatar
My FMF has worked out great for me. There is a definite power increase, and I can almost tolerate the added noise!
Old Jan 8, 2001 | 01:31 PM
54warrior's Avatar
All i have to say is don't get a DG. I have a stock 96 warrior, and i rode a 98 warrior with a DG complete system. it was terrible, there was LESS power, and it was very poorly made. it rattled and clanged around the whole time.
I like the looks of the new Pro-Circuit,and the white-bros. R-series
Old Jan 8, 2001 | 10:42 PM
speedster350's Avatar
hey
i have a 98 warrior and i have the team alba kit on mine. Noticable low and mid power. It is the same as a white bros just a little different design at the end by the discs. The kit is around 280 but you get your jets k&n filter and outerwear and a torque stuffer. It was the best mod to my warrior
go to www.albaaction.com trust me it is a good pipe
hope i helped
speedster
98 warrior---sur trak tires on douglas rims, ac nerfs, renthal bars, alba pipe, k&n filter and outerwear, team alba shock covers, works a-1 steelers front socks, and stock cromed head pipe.
mods soon to get-
398cc kit
team alba air box
holeshots xct front
Old Jan 9, 2001 | 03:40 PM
PC_350_Warrior's Avatar
I have a '96 Warrior with the White Brothers E-Series silencer...and I love it. The sound level is a bit loud....but I prefer it like that. It sounds awesome...meaner than my friends 400EX's. And it looks great...I noticed an increase in power the first time I rode with it. Seems like I get more torque and can pull wheelies easier. I also went up to a 15 tooth c/s sprocket with my 20" Bandit tires....perfect set up.
Old Jan 9, 2001 | 06:10 PM
A99wolverine's Avatar
I have a wolverine with a procircuit pipe on it, It sounds awesome and if its too loud they make a quiet baffle for it, it also has 3 different tunable end caps for torque midrange and top end. I have the stock all around end cap and its great power is much better i can easily pop wheelies now and it revs out way better on top, I also installed the prodesign system with foam filter, and bumped up the jetting a bit. I would highly recommend the procircuit, if you choose another system make sure its a megaphone style system without a restrictive end cap like those on the megamaxII e-series and supercrap. I have seen several pipes on the dyno at a local shop, the same shop that put nitrous on the raptor in the february issue of dirtwheels. And the pipes like the procircuit, FMF IV2,R-series, dmc,lrd. Put out more power, also look for a spark arrested muffler that dosent require the power robbing end caps found on those like the megamax2 and supertrapp. The procircuit can also be polished to a mirror finish with some elbow grease.
Good Luck, and I hope you enjoy whichever new pipe you choose to buy!
Andrew Humphrey
Louisville Ky
Old Jan 11, 2001 | 02:35 PM
quadcrazy's Avatar
You obivously aren't to bright. I happen to have a SUPERTRAPP exhaust on my warrior. The closed end cap is the spark arrester. I uncorked mine when I ride at the track or when I'm racing. Believe me it's load but sounds very throaty. It will be the best sounding fourstroke on the track. I have had many people tell me that it sounds awesome and very healthy. You put the plates (end cap) back on for trail riding.
98 warrior
supertrapp exhaust
10.5:1 wiseco piston
web racing cam and springs
head ported and polished
durablue 2+2 axle
20" dunlops on all 4's
Old Jan 11, 2001 | 10:57 PM
you obviously cant read! moron, I said that she should purchase a pipe that has a spark arrester other than the type that closes the end of the muffler, put your hand over your mouth and try to breath, keep it there until you pass out... moron, and learn how air flows through a muffler, then you will under stand why every top engine builder. in any sport does not use a disc type muffler, any time you restrict flow you restrict horsepower, therefor by adding discs to any muffler you restrict its flow, for results read above. If you restrict flow it is sometimes possible to gain bottom end, in the form of torque, but you will sacrifice top end, and maximum horsepower... If you think I am not very bright, continue the use of your supercrapp and realize, that when you need extra power on the trail that you cant have it, because you will be breaking forrestry service laws, by doing so. I did not once insult your intelligence nor your exhaust contraption, it is mearly my opinion and hypothesis, based upon facts, and dyno results,sorry but dont insult me unless I insult you first!
mrtidy
Feb 3, 2016 05:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
ltzbrad
Sep 25, 2015 05:52 PM
Bernhard
Sep 25, 2015 12:45 PM
greg86hd
Sep 16, 2015 12:32 AM
