how to
Old Nov 7, 2007 | 11:24 PM
polaris man's Avatar
Default how to
how to clean the muffler on a 425 magnum what can i put in it to clean it that wont hurt the spark arrestor
Old Nov 8, 2007 | 10:06 AM
94harley's Avatar
Default how to
What problem are you having that makes you think the muffler needs cleaned?
Old Nov 8, 2007 | 02:51 PM
Default how to
it starts to blow black smoke and when i tapped on the muffler it stopped and also it will backfire
Old Nov 8, 2007 | 06:56 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Default how to
Does it have a threaded "PLUG" in the muffler???.....Caper.........
Old Nov 8, 2007 | 07:14 PM
Default how to
yes i took it out and a little stuff came out / if its not the muffler any idea waht else it could be
Old Nov 8, 2007 | 07:22 PM
94harley's Avatar
Default how to
Is it backfiring through the carb? Did this start all of a sudden or gradualy get to this point. If it pops through the carb it could be the exhaust lobe on the cam is gone. It could also need a carb rebuild if it's running rich, the popping may be from a fouled plug. Any more info you can give us?
Old Nov 9, 2007 | 11:26 AM
Default how to
it just started all of a sudden but i have been running it for two days now and it hasnt done any more / also what is the ehaust lobe? it didnt do it until i was just running about 5 to 10 mph for about 15 minutes then it started to sputter like it was out of gas then started backfiring and blowing black smoke
Old Nov 9, 2007 | 11:58 AM
94harley's Avatar
Default how to
I would replace the spark plug and have the carb gone through. Sounds like youre running rich and fouled a plug to me.
Check and see if there is a bracket holding the rear of the carburetor that bolts to the frame. There should be a bracket that is screwed to the carb and then goes to the frame and is secured there with what looks like tiny motor mounts. A rubber dampner with a stud threaded into the frame and the other goes through the carb bracket and is held on with washers and nuts. What year is your machine?
Old Nov 9, 2007 | 01:08 PM
Default how to
it is a 1998 425 magnum also now i can smell a little gas in the oil
Old Nov 9, 2007 | 01:33 PM
94harley's Avatar
Default how to
The carb needs to be rebuilt. Did you see the bracket holdint the rear of the carb?
