Clutch killed my cover
Old Nov 9, 2007 | 10:48 AM
HFD84's Avatar
Default Clutch killed my cover
used wheeler I bought has a nasty clunking and rubbing noise in the clutch cover. I took it off and the clutch has worn a hole right down in the bottom of the cover. Why is this doing this? I have read that it might be a warped cover. Is this something that happens a lot if the wheeler is not used properly. Motor mounts look good. Any body have this happen to there wheeler before why is the clutch eating up my cover??
Old Nov 9, 2007 | 10:55 AM
scootergptx's Avatar
Supersock
Hired Gun!
What kind of shape was the belt in? If the belt shreds, it would do what you are describing, and would be a lot less costly to fix.
If the clutch sheaves themselves are rubbing the cover, first check to see if the back and front covers are installed properly, and look for warping.
If that all checks out, unfortunately, it could be a costly repair.
Old Nov 9, 2007 | 11:03 AM
TLC's Avatar
TLC
A warped cover that allows the clutch to rub would be super obvious to spot. Take of the cover and rev the motor and see if anything is wrong with the movement of the clutch and secondary. It should behave like the end of this video. http://www.youtube.com/watch?v=8_HhKSY3Ro8
HFD84's Avatar
Belt is in good shape seems to be the bottom of the primary clutch and a little on the secondary. With good luck this will just be a warped clutch. Any one know how hot these things get inside the cover?
Old Nov 9, 2007 | 02:45 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
on the older models the cover sometimes would get stepped on or what not and it would push sown onto the clutch and wear a hole in it. make sure theres no bad bearing making it move around ad well.
Old Nov 9, 2007 | 02:49 PM
Supersock
Hired Gun!
It can get pretty warm in there. While you're checking, follow the clutch snorkel and make sure nothing is clogging it.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
ghost civic
Jan 15, 2020 07:43 AM
Cummins Driver
Sep 11, 2019 01:22 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
