changing a ball joint
Old Nov 11, 2007 | 08:13 PM
scram-shee's Avatar
Default changing a ball joint
I have a 400 scrambler and i need to change the ball joint. I'd rather know the right way then tearing it apart and not being sure.
Old Nov 11, 2007 | 11:35 PM
94harley's Avatar
I put the new ball joint in the freezer(cooling it off makes it shrink a tiny bit) Stand the machine up on its rear rack(it will stand up on its own) Remove the wheel, a-arm, Pull the ball joint, reinstall the new one(special tools very helpful) Put the a arm back on, put the wheel back on set it down. Done. Be carefull not to lengthen the axle any more than you have to on 4wd's, they can come apart in the cv joint and then you can't reassemble the machine till you get the axle put back together.
jankerstien
Sep 21, 2015 03:09 AM
bigbear350quad
Sep 11, 2015 12:40 PM
89Lt250r
Sep 7, 2015 07:53 PM
Jason Campbell
Sep 7, 2015 02:25 PM
Elkaholic
Sep 6, 2015 02:44 PM
