Oil Weight?
Old Nov 14, 2007 | 08:58 PM
florencedunes's Avatar
Default Oil Weight?
Can I run other weight oil without damaging the motor? I live in a mild climate which ranges from 40F to 85F.
Old Nov 14, 2007 | 10:34 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Oil Weight?
stick w/ what they recommend and leave the synth. in as well and dont go to conventional oil.
Old Nov 14, 2007 | 11:34 PM
SCRAMMYTODD's Avatar
Default Oil Weight?
If you go to a heavier oil or a conventional oil the top end may starve for oil as they are a low pressure oil system. Especially in cold climates
Old Nov 15, 2007 | 02:06 AM
sheepdogMSP8117's Avatar
Default Oil Weight?
I'd stick with the 0W-40, and also stay Synthetic, but switch brands if you'd like. I'm currently using Amsoil FFS 0W-40.
Old Nov 15, 2007 | 06:42 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Oil Weight?
it only takes about 2 qts of oil and you dont change it that often. some use mobil 1 and others use amsoil or just buy the polaris. either way use the what it calls for for sure.
Old Nov 15, 2007 | 08:01 AM
ftwflh's Avatar
Default Oil Weight?
Polaris went with the 0w40 back in the mid 90s due to topend oil problems.this is eliminated with the 0w40 synthetic.So best to stay with it.
shimanok2
Jan 29, 2016 07:37 PM
Robinhood
Dec 26, 2015 10:28 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
