POLARIS OVER HEATING ?
Old Nov 21, 2007 | 08:35 AM
dreth's Avatar
Default POLARIS OVER HEATING ?
2 friends of mine have 04 500 sportsman HO, the display is flashing "HOT" "HOT" "HOT. I have cleaned the radiator to a shine, changed the fluid and the fan works. What can it be?
Old Nov 21, 2007 | 10:05 AM
RolliePollieOllie's Avatar
faulty sensor?
Old Nov 21, 2007 | 11:21 AM
TLC's Avatar
TLC
When they really over heat the coolant blows out of the reservoir bottle.
Old Nov 21, 2007 | 01:13 PM
94harley's Avatar
Are they 2004.5's? The ECM issues were for a few 04.5's. It sure sounds like the problem. Any chance of getting vin numbers?
Old Nov 21, 2007 | 02:11 PM
dreth's Avatar
they are 04.5 so what does that mean and what should i do??? THANKS! its driving me crazy
Old Nov 21, 2007 | 03:51 PM
94harley's Avatar
There was a ECM recall for the 04.5's. Call your dealer with the vin numbers or PM it to me and have them checked to see if they have had the ECM test done already. If they haven't, you should be able to get the machines fixed for free. If they have been checked and passed, you will probably just have to order 2 ECM's and replace them.
Old Nov 21, 2007 | 05:48 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Can you see light through the rad???.........Is the back side CLEAN(fan side)??................
They may look very clean from the front ....But it's the back that plugs up!!.......Caper...........
Old Nov 21, 2007 | 05:50 PM
SCRAMMYTODD's Avatar
Could be a stuck thermostat as well. I had to put one in my Scrambler and it was stuck shut.
Old Nov 21, 2007 | 07:42 PM
dreth's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 94harley
There was a ECM recall for the 04.5's. Call your dealer with the vin numbers or PM it to me and have them checked to see if they have had the ECM test done already. If they haven't, you should be able to get the machines fixed for free. If they have been checked and passed, you will probably just have to order 2 ECM's and replace them.</end quote></div>
where is this ecm located and how much do they cost? the paper work says that its out of warranty.
Old Nov 21, 2007 | 07:44 PM
dreth's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: caperinmuskoka
They may look very clean from the front ....But it's the back that plugs up!!.......Caper...........</end quote></div>
i can see light through every inch of it. i literally took the rad. out of the quad to clean it.
