ADC Ratio Question
Old Nov 21, 2007 | 10:47 AM
Totun's Avatar
Default ADC Ratio Question
Based on a non ADC Model the rear gear ratio over drives the front to prevent the front hub from locking in Four WD until the rears slip 1/5th of a turn. When the ADC is engaged all four wheels have engine braking. Do all four wheels rotate at the same speed or are they still subject to the gear ratio differences between the front and rear diffs? Just trying to wrap my head around it.
Totun
Old Nov 21, 2007 | 12:14 PM
RickCJ7's Avatar
I would say there is a differance, as the rears just start to slide the front will kick in and hold back as needed, this way you you can easily steer. It works so fast you can barely tell its working. Just switch into 2wd and then you'll notice the differance.
EIF
Apr 20, 2017 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
Honski250r
Sep 26, 2015 09:40 PM
rockinkgin
Sep 25, 2015 01:52 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
